How do I reset flashing lights error condition on my printer?
Occasionally, some users will experience the error on their printer where it
stops printing and all the lights start flashing. Different printer models may
have different descriptions of this error, but it seems to be generally
described as a 'Unknown Printer Error'. In fact, numerous users in the internet
community believe that this error is most often experienced when the printer has
reached a condition where it thinks the ink waste pads inside the printer are
full. That's right - all that ink you lose in cleaning cycles and priming new
cartridges has to go somewhere, and your Epson printer keeps track of roughly
how much ink it has dumped into some large absorbent pads in the base of the
printer!
Technically, this condition requires an Epson service engineer to resolve. It
is however, possible that you could fix it yourself by resetting the printer and
clearing the counter of how much ink has gone to those pads. You can do this as
follows: (this seems to work on numerous Epson desktop printers, but we make no
claims about it's reliability on your printer. Use at own risk etc!) However, we
now have three separate procedures supplied by various users; it seems that
there are either different reset procedures depending upon printer model, or
something else is going on that we do no understand!
Additionally, we are now starting to hear about similar-sounding issues with
the 2100 printer - except the printer is helpfully warning of the error before
it just stops printing! The message you will see says something like 'Parts
inside the printer are nearing the end of their service life'. Presumably at
some time it will just refuse to print, unless the problem is addressed more
directly.
- DOES YOUR PRINTER STOP TO PRINT AND SAY PARTS INSIDE YOUR PRINTER ARE AT THE END OF THEIR LIFE?
- DOES IT SAY INK PADS NEED CHANGING?
- HAVE YOU GOT AN E-letter IN THE DISPLAY AND FLASHING LIGHTS?
- ARE YOU BEING TOLD TO TAKE YOUR PRINTER TO AN EPSON SERVICE CENTER?
DONT BUY A NEW PRINTER! DONT TAKE YOUR PRINTER TO A SERVICE CENTER AS YOU JUST NEED TO RESET THE INTERNAL WASTE INK COUNTERS INSIDE YOUR PRINTER AND THEN IT WILL WORK PERFECTLY AGAIN!
Procedure 1
THE WIC Reset Utility WILL RESET Your Epson Inkjet Printers WASTE INK COUNTERS which are stopping You from printing.
IF YOU DID NOT ALREADY KNOW EPSON BUILD IN TO THEIR PRINTERS A SYSTEM WHERE BY THE PRINTER WILL STOP WORKING AND REQUIRE ATTENTION FROM A SERVICE CENTER TO GET THEM WORKING AGAIN. THEY DO NOT NEED A SERVICE THEY JUST NEED TO BE RESET.THE WIC SOFTWARE STOPS THE NEED FOR YOU TO TAKE IT TO A SERVICE CENTER AS YOU CAN NOW DO IT YOURSELF IN 2 CLICKS!
EASY TO USE AND COMES WITH FULL INSTRUCTIONS AND GREAT AFTERSALE HELP SHOULD YOU NEED IT
IF IT DOES NOT THEN WE WILL REFUND YOUR MONEY. NO QUIBBLE!
The reset is very simple and easy:
1. Run the program under Windows OS and click RESET button.
2. Enter RESET KEY (What is this?) and click OK - that is it!
You can now Reset Your Printers Waste Ink Counters in 2 clicks!
WIC RESET UTILITY CAN:
- check the current value of waste ink counters and ink level counters (FREE)
- reset Waste Ink Counters (require RESET KEY - you have to buy RESET KEY- BUY RESET KEY)
- reset Ink Level counters in printers L100, L200, L800 only (FREE)
- cleaning printhead (FREE)
- Ink charge (FREE)
- read and write serial number (FREE)
- read and write USB ID (FREE)
- read and write HEAD ID (FREE)
- make EEPROM dump, backup (FREE)
- paper feed test (FREE)
- nozzle check (FREE)
- color check pattern (FREE)
- initialize (disable) PF deterioration offset (FREE)
- retrieve device information (FREE)
Procedure 2
We found this procedure to work for the Stylus Photo 1270 type printer, and
understand that it also works for the 870 range and even earlier models like the
Stylus Color 740. The error is indicated on these printers by all four lights on
the printer flashing. Even if you press the power switch on the printer, the
lights continue to flash, and the printer does not turn off!
Turn off your printer, ensuring that the print head is at it's home location
and locked in place as normal;
Power off the printer at the wall or by removing the power cable, for at
least 20 seconds;
When you restore power to the printer at the wall socket or by reinserting
the cable, if the lights come back on straight away, the printer's power switch
was 'on' - switch it off and return to step 1;
Hold down the paper-feed button and the button with the ink-drops next to
it, and then turn on the printer, still holding the buttons down;
When the paper-out LED flashes, release the buttons;
Press and hold the Cleaning button, until several lights flash - this will
take a few seconds (i.e. then release the button);
The printer will now attempt to reset, including resetting the EEPROM memory
and running a short (about 10 seconds) cleaning cycle.
Procedure 3
Hold down the paper feed button only;
Turn on the printer;
As the paper feed light starts flashing, release the button;
Immediately hold down the ink-drops button for some 10-20 seconds or until
the printer springs into life;
Allow printer to complete it's processing, then turn off for a few seconds,
and back on again for a newly working printer!
Procedure 4 - for 1290 and possibly 890 printers
1290 printer with green (power / data) and red (ink / paper feed) lights
flashing alternately:
Switch off printer with panel switch;
Switch off printer at mains switch - leave off for 20+ seconds;
Hold down roll feed and sheet feed buttons;
Switch on at mains;
Switch on at printer panel;
Continue to hold down roll and sheet feed buttons until both green and red
lights flash together in synchronisation, not alternately;
Switch printer off and then, after a few seconds, on again at mains switch;
When red and green lights are both flashing in synchronisation, release the
roll and sheet feed buttons;
Press and hold down the ROLL FEED button (the one at the extreme left) and
keep it down until the machine finishes whirring, cleaning etc and the green
light comes on steady;
Release the roll feed button and all should be well.
Procedure 5 - Cheat with Software Reset Methods!
There is a software reset method that can be used to reset ink levels.
It is recommended to use in Epson service centers. Each printer model has specifyed service (adjustment) program
which has such option like Reset Protection Counter when you need to reset the value
of Wate Ink Counter. You can learn more about software reset method at this link: About Service Programs.
This programs can be used to reset a number of counters in the printer, etc.
Please note that CIS users should probably steer clear of any resetting of
cartridge ink levels in the printer, and you will probably need to look for the
'Protection Counter'. Due to the risks of resetting this protection counter, it
may be preferable to use the software once to reset the counter, then uninstall
it so you do not inadvertently reset the counter more than once.
According to it's own readouts, it did reset the 'protection' counter... but pretty much did
so of it's own accord. It then seemed to interfere with printing! However, the
access to advanced cleaning function control etc looks useful. Nevertheless -
use with caution as per the notes above!
Reset Error Light Conditions Summary
OK - so whilst we have heard this resolves the problem, it may not do so for
you, and whilst we have heard that the ink-pad error is most likely way before
the ink pads are actually full, we think it will be OK. However, you should be
aware that IF your ink pads were full then resetting the counter on the printer
without replacing the pads could ultimately cause damage to your printer and
surrounding areas as inks starts to pool inside the printer base and potentially
leak out. We suspect that this will not happen for the vast majority of people,
but it is certainly possible. We have now heard of this occurring for a
couple of people.
Instructing you how to dismantle the printer to examine the waste ink pads is
currently outside the scope of our support assistance (though we have done this
task ourselves with minimum fuss). You may like to refer to our
Service Manuals page
and
Spares Printers Parts UNICOMP site.
Reset waste ink counter by adjustment program
Since your printer consumes ink not only for printing but also for other operations
like cleaning, a certain amount of ink is wasted and it is collected by the
waste ink pad. Therefore, the printer counts the amount of waste ink.
Once the amount of waste ink reaches the predefined limit, the printer indicates
"MAINTENANCE REQUEST" and the waste ink pad should be replaced.
Also, you must reset the maintenance error condition and the waste ink counter
value stored in EEPROM on the mainbord of the printer.
The adjustment program enables you to perform maintenance and adjustment functions
such as:
EEPROM initial setting
Waste Ink Pad Counter reset
Initial Ink Charge
Head ID Setting
Top margin Adjustment
Bi-D Adjustment
USB ID Input
Note: This example shows you how to reset waste ink counter of Epson R280, R285, R290 printers.
Other printer models may have different set of functions, and you must doublecheck the service manual for a specific printer
that you are going to troubleshoot. Warning: misuse of a program may damage printer's EEPROM! Run the program under Window XP only.
How to reset waste ink counter by adjustment service program ( for example R290 model).
1. Download the (Epson R290) adjustment program from www.2manuals.com.
2. Save archive and unpack by WinZip
3. Run AdjProg.exe program under Windows XP or under Windows 7 or Vista IN XP Compatibility mode. Press ACCEPT.
4. In new window check Particular adjustment mode.
5. Then check Waste ink pad counter option.
6. Click CHECK for checkin counter value.
7. To reset waste ink counter check 2 times and press INITIALIZATION.
8. Then press OK.
9. Resetting process is for few seconds and looks like:
10. For finishing power off the printer. The data will save up in the printers EEPROM. There will appear message:.
Switch the power ON and check the counters value.
Other printer models adjustment programs work the same way.
New Epson adjustment programs are updated every week on www.2manuals.com
